aerender render by comp name
Jovche Malakovski
on Dec 18, 2017 at 9:57:59 am
Hi
When rendering with aerender and using the -comp argument there is an issue if you have two comps with the same name.
Is there some solution for this, that does not involve changing the name of the comps?
Walter Soyka
Re: aerender render by comp name
on Dec 18, 2017 at 3:14:21 pm
Can you test to see if aerender is consistently using either the first or last identically-named comp in the project, then re-arrange the order of the items in the project panel accordingly?
Walter Soyka
