Change Paragraph Alignment for a text layer
Mateo Baldasare
on Dec 10, 2017 at 11:56:20 pm
Hi there!
I'm working on a rig for some text layers to align them to the left, center, or right. I wonder if there is another way (apart from the Paragraph panel) to change the text alignment. So when I change the position of the layer, it'll automatically adjust the alignment (without having to go each time to the Paragraph panel).
Is it possible?
Kalleheikki Kannisto
Re: Change Paragraph Alignment for a text layer
on Dec 14, 2017 at 6:25:29 pm
I guess you could make three text layers with those alignments and then use an expression to copy the source text and determine which one is shown (the one you want to show at opacity 100, others 0).
Senior Graphic Designer
Eric Santiago
on Dec 14, 2017 at 6:52:46 pm
Would this help:
https://forums.creativecow.net/thread/2/1068764
