track a glowing dot problem
Manuel Del Negro
on Dec 9, 2017 at 6:55:48 pm
Hi, sorry for the newby question,
i have an animated stroke with a glow and i want to motion track the glowing dot, but when i try that the tracker simply goes randomly down left the comp.
All i want to do is track the glowing dot and apply the position keys to a null object.
(i already tried to copy paste the mask of the stroke into the null position prop, but it does not work, seems it paste a mask to the null and the null disapper O_0 )
i can't understand why the mask to position trick does not work and why the tracker seems to completely ignore the glow and go randomly around the black background.
Sorry for my english
the animation and the mask on the links below
https://ibb.co/mWJSjb
https://ibb.co/njRSHw
Richard Garabedain
Re: track a glowing dot problem
on Dec 11, 2017 at 5:08:38 pm
those look like shapes and not masks to me..which would make it not work.. But its hard to tell. I would track something then add a glow after wards.
Manuel Del Negro
on Dec 11, 2017 at 8:26:19 pm
I got it to work normally after i reinstalled AE....It has perfectly tracked every single frame. Thx for the answer anyway
