Animating the scale of a motion path [solved!]
Brian Nishii
on Dec 9, 2017 at 12:11:21 am
I have a flare parented to a null that is moving along a motion path.
Is there anyway to animate the scale of the motion path while the flare is moving along the said path?
I know you can copy/paste motion motion path to shape path and scale, but to animate it?
[EDIT]
In case anyone stumbles onto this, I found an elegant solution to what I wanted to do using Dan's space transformations here:
So,
1) "TargetNull" follows a motion path inside a PreComp.
2) PreComp is resting in a MasterComp with collapse transformations.
3) "FollowNull" will follow the TargetNull with these expressions in position parameter:
L1 = comp("PreComp").layer("TargetNull");
P1 = L1.toWorld(L1.anchorPoint);
L2 = thisComp.layer("PreComp");
L2.toWorld(P1);
Now, I can scale the PreComp inside the MasterComp, and my FollowNull will follow nicely!!
As always, Mr. Ebberts is the KING!
