Skybox, Element 3d crash
Bruce Cam
on Dec 8, 2017 at 10:57:49 pm
I am rendering a Motion Graphics 360 fish eye dome animation using Skybox.
I am using element 3d, form, particular among others in the scene.
This happened last night with 1 machine when i tried to render and it has happened again tonight with 2.
Renders are heavy as expected so i am sharing the workload across 3 machines. However 2 of the machines seem to start having issues with element. If i monitor the frames i noticed that the ambient occlusion started to drop on the 2 problematic machines.
I stopped the machine that is rendering the bad frames and then it gives the error for Video Copilot: GPU failure, please reinstall etc. If i then try open a skybox file even one without element i get the following error: "After effects can't continue: SkyBox Converter plug-in generated bad result"
Now i can't do anything on those machines, my IT support done something on the problematic one from yesterday get it working again but this is no good if it happens every time. Fingers crossed my main machine is working and doesnt have the problem.
They are all the same spec machines with Titan X cards.
Anyone had similar issues with skybox / element?
Cheers,
