Select a specific layer in the timeline panel
Rudy Lee
on Dec 4, 2017 at 9:26:40 am
I am not sure whether this possible but I'll just ask.
Does anyone know how to select a specific layer after opening the root comp in the viewer ? Basically, I want to be able to select and cut a specific layer. See the image below:
This is the code that I have so far
pal.btn1.debugBtn.onClick = function ()
var file = importFile()
var layer = file.layer(2)
app.project.showWindow(true);
file.openInViewer()
layer.selected = true
app.executeCommand(18)
Walter Soyka
Re: Select a specific layer in the timeline panel
on Dec 4, 2017 at 5:41:00 pm
When you open a comp in the viewer, it becomes the "active item" in After Effects. You could then select the third layer like this:
// deselect all layers in the active comp -- just in case
for (var i = 1; i <= app.project.activeItem.numLayers; i++) {
app.project.activeItem.layer(i).selected = false;
// select the third layer of the active comp
app.project.activeItem.layer(3).selected = true;
Walter Soyka
Rudy Lee
on Dec 4, 2017 at 6:46:46 pm
Hi Walter,
That works, thank you so much for the help.
Rudy
