3D plane model in a 360° landscape
Alex Reve
on Dec 2, 2017 at 3:35:38 pm
Hello,
Can someone tell me if it is possible to animate a 3D model (a plane above in the sky) inside a 360° environment. The idea is that for exemple, the plane arrive from very far in the sky in the horizon on the left, then pass above us, and disappear in the horizon on the right. Will the view we will have on that plane from the ground will be correct and realistic in terms of what angles we will see of it?
Thanks by advance
Kalleheikki Kannisto
Re: 3D plane model in a 360° landscape
on Dec 4, 2017 at 10:28:10 am
The "Skybox" suite of effects that is included in AECC2018 is meant for editing 360 footage, adding 2D and 3D content into it, etc. Adobe recently acquired Skybox from Mettle, not sure if the documentation is currently of Mettle or Adobe site.
Senior Graphic Designer
Mark Whitney
on Dec 4, 2017 at 2:26:34 pm
There's also Skydome which gets around some of the issues with SkyBox.
