Looping Walk Cycle Glitch
Ryan Beaton
on Nov 30, 2017 at 6:34:52 am
I'm trying to create a simple walking animation, and I've gotten the loop to work, but for some reason, when I try to move the pre-comp across the screen while motion blur is enabled, I get a weird visual glitch at the beginning of each loop. With motion blur off, the problem goes away, but I was hoping to be able to use motion blur. Does anyone know why this is happening?
I've fixed the common issue with the blank frame when doing a loopOut expression, so I know that's not the issue.
I have screencaps of a non-glitched and glitched frame
