Create New Sequence from Photoshop Layer Comp
Peter Jones
on Nov 29, 2017 at 12:12:58 pm
Hi CC,
Is there a script that will automatically create New Sequences from Layer Comps? My graphic designer has generated hundreds of Layer Comps in Photoshop.
Or is it best to export hundreds of new Photoshop files and then import as comp?
Let me know
thanks - Pete
senior editor
Ian Watkins
Re: Create New Sequence from Photoshop Layer Comp
on Nov 29, 2017 at 3:42:11 pm
Not sure about scripts, but Photoshop folders will import as comps in AE. So if you put all those files from the comps into folders in PS, you should get what you want automatically.
Hope that helps!
Ian
