Puppet tool removal – keep end position
Katie Cadwallader
on Nov 29, 2017 at 12:07:29 pm
As a workaround for using a camera & the puppet tool without the crazy glitches, I've duplicated the layer so I can keep the end position of the character and remove the puppet tool before the camera pans again.
Whenever I remove it, the character springs back to it's original position. Is there a way around this?
Thanks – Katie
Ian Watkins
Re: Puppet tool removal – keep end position
on Nov 29, 2017 at 3:50:45 pm
Once you remove those pins, you remove the scripting, so it won't keep it's position. I don't think there is a way to bake the pins. Try "save frame as" with an alpha channel on your pinned character and then import image as a layer.
I suggest designing the character in PS or AI in the position you want, or look up rigging tutorials. Puppet pin tool doesn't always give you the cleanest bends, so that's one way to ensure the best quality.
