Turning something straight into a circle
Zack Culver
on Nov 27, 2017 at 1:21:41 am
I swear I have seen this done before...
I need to take an existing piece of footage that is "flat" and turn it in to a circle. Not mask it out into only showing a circle of the image. I need the end points of the horizon to loop around and touch each other. So that what is straight lines in the footage will become a circle. Is this possible?
Fuller context: I have a looping animation of an old-school 80s grid coming straight towards you. Its just generic stock I didn't make it from scratch in After Effects. I need to "twist" this footage around so that the flat horizon grid becomes a tunnel. I could not find a free stock loop of a grid tunnel. If I need to make a grid from scratch in AE to make it into a tunnel I have seen those tutorials... I guess I would just need to know what the effect would be called to circularize it. Its not "circle" that just creates a vector circle... and I didn;t find any sort of "array" effect like I would think of in other types of software. I just at least need a starting point.
TL:DR - how do 3D grid tunnel?
Dave LaRonde
Re: Turning something straight into a circle
on Nov 27, 2017 at 2:37:05 am
If it HAS to wrap into a tunnel shape, read no further.
But it can already be a tunnel shape give CC Cylinder a look-see.
Dave LaRonde
Promotion Producer
Zack Culver
on Nov 27, 2017 at 3:23:07 am
Tried that didn't quite give me what I wanted. I did the CC Bend It to the animation and it wasn't REALLY what I wanted but it will work in a pinch I guess.
Zack Culver
on Nov 27, 2017 at 3:16:53 pm
I thought maybe a picture reference would help...
So imagine this tunnel went back and down not to the right... I need that but animated, not necessarily that you're flying through / down it, but that it is "flowing" towards you .
Kevin Camin
on Nov 28, 2017 at 5:36:49 am
I feel like this would be a dedicated 3D program solve. To me it sounds complicated even though the result looks "simple" and clean.
Best regards,
Kevin Camin
Zack Culver
on Nov 28, 2017 at 4:37:42 pm
Yeah if I had 3DS Max or something I could just fart out a funnel and run a camera through it. I'm working with what I have...
The cylinder idea earlier may work. I didn't realize all the options at first that I could go inside the cylinder.
Joseph W. Bourke
on Nov 28, 2017 at 7:33:09 pm
Zack -
It looks like Transformer might help you out. Look at the paths capability:
https://aescripts.com/transformer/
Joe Bourke
Owner/Creative Director
Bourke Media
http://www.bourkemedia.com
