3d X Rotation out of the screen
Bedo Nada
on Nov 24, 2017 at 5:01:52 am
Hi everyone,
When i try to Rotate a solid ( 3d X Rotation ) at the bottom of the screen.. It goes out of the screen
is there's any way to make it rotate like front camera
Mark Whitney
Re: 3d X Rotation out of the screen
on Nov 25, 2017 at 3:29:09 am
Basic stuff. Check where the objects Anchor point is. You might be able to simply reset it's transform properties. You might do the same for your camera as well.
Bedo Nada
on Nov 25, 2017 at 9:18:14 am
I'm sorry I made a mistake.. I was meant 3D "Y" Rotation
Richard Garabedain
on Nov 27, 2017 at 4:52:33 pm
check active camera to make sure it says actuve camera or front...i cant tell from your picture what is going on
