middle null object expression?>
Jakub Wiśniewski
on Nov 23, 2017 at 6:10:49 am
Hello,
I have two null objects which are trackers.
I need to create 3rd obj which will be exactly in the middle of my trackers.
What should I do?
Walter Soyka
Re: middle null object expression?>
on Nov 24, 2017 at 4:03:22 pm
You just need the average of the two points. Something like this will work as an expression on the position property of a null layer (modify layer/tracker names as necessary to suit your comp):
p1 = thisComp.layer("TRACK_LAYER").motionTracker("Tracker 1")("Track Point 1").attachPoint;
p2 = thisComp.layer("TRACK_LAYER").motionTracker("Tracker 1")("Track Point 2").attachPoint;
(p1+p2)/2
Walter Soyka
