Sound when dragging slider
Wayne Nort
on Nov 21, 2017 at 9:44:53 am
I'm trying to match visuals with sound peaks in the audio.
Can after effects play the sound when manually dragging the slider.
If so how can it be enabled?
Walter Soyka
Re: Sound when dragging slider
on Nov 21, 2017 at 7:38:14 pm
No, but you can add markers in the timeline panel during playback by tapping the asterisk key on the numeric keyboard.
Or you could use the "Convert Audio to Keyframes" keyframe assistant: right-click your audio layer, then navigate to Keyframe Assistant > Convert Audio to Keyframes.
Or you could use Trapcode SoundKeys for more control over how the audio is sampled and interpolated.
Walter Soyka
Wayne Nort
on Nov 22, 2017 at 10:30:52 am
Worked it out
Ctrl + Alt + Drag Slider
Walter Soyka
on Nov 22, 2017 at 7:11:26 pm
Oh, sorry! I completely misunderstood you. What you're describing is called the Current Time Indicator (CTI, also sometimes called the playhead). A slider is an effect control.
I'm glad you found the solution.
Walter Soyka
Roei Tzoref
on Nov 24, 2017 at 8:52:55 am
Just Ctrl...
Roei Tzoref
2D/VFX Generalist & Instructor
♫ AeBlues Tutorials ♫
http://www.tzoref.com
faisal Rubai
on Nov 27, 2017 at 8:07:30 am
CTRL+ Press the time indicator
