Animate flattened 3d image
Ryan Hughes
on Nov 16, 2017 at 8:41:21 pm
I would like to rotate the circle of arrows below. I only have access to this flattened image. I'm wondering if there are any techniques to making this circle appear to rotate naturally without having to recreate 2d arrows and place them into a 3d space. Thanks!
Eric Santiago
Re: Animate flattened 3d image
on Nov 16, 2017 at 9:08:18 pm
Switch the 3D toggle on and make sure the pivot/axis is dead center.
Then go to down with rotation use all angles and/or use Camera.
Ryan Hughes
on Nov 16, 2017 at 9:12:52 pm
Right, but that will look distorted since the arrows are in a circle at an angle.
Walter Soyka
on Nov 17, 2017 at 12:43:10 am
I'd try to reverse the perspective with CC Power Pin, rotate, then re-apply perspective with CC Power Pin again.
Walter Soyka
Mark Suszko
on Nov 17, 2017 at 9:21:40 pm
There's no reason you couldn't just re-create a flat, centered, un-tilted version of this graphic, then make it spin and adjust the angle. You'd have perfect control of every aspect then. Unless there's some reason you're married to that exact graphic?
