time warp question
therman mermehn
time warp question
on Nov 16, 2017 at 4:04:20 pm
I'm using timewarp on a 24fps sequence.
From what I originally understood/assumed , timewarp built frames in between existing frames , and left the original frame alone. however i can see that it also changes the original frames slightly as well.
For example , a video of a moving picket fence , obviously it won't timewarp 100% perfectly but it would be acceptable if some of the frames were original. However , it seems it warps every frame. So the fence would look warped or misaligned in every single frame as opposed to every other frame.
Is there a way to have time warp ONLY create new frames in between and not affect existing ones?
