After Effects > Trapcode Particular > Sprite Particle rotation
Matt James
on Nov 14, 2017 at 10:21:59 am
Hi all.
Feel free to berate me as the answer is probably right in front of my nose;
I have a sprite particle in Particular with a small Z rotation on it so it slowly rotates. Positive = clockwise, negative = anti/counter clockwise.
I'm sure that in the past I have managed to have half the particles rotate CW and half CCW but I can't for the life of me work out how to do it now.
Thanks in advance!
Cassius Marques
Re: After Effects > Trapcode Particular > Sprite Particle rotation
on Nov 14, 2017 at 1:33:10 pm
You have a property called random Z rotation (or something like that). Thats what you should change (Its totally counterintuitive, I know)
I got really pissed when I discovered that Stardust has that same hindrance... I had to duplicate the emitter just so I could get particles to spin the other way.
Thats one way to do it too with particular if you want the exactly same rotation value (and not a random one), just CW and CCW. Duplicate the effect with properties, and change the rotation value and the seed number.
Cassius Marques
http://www.zapfilmes.com
