Working with MTS files & Clone Stamp tool
Jerrett Wilson
on Nov 6, 2017 at 11:42:59 pm
I'm working on a project where I'm needing to cover a wall mounted AC unit. I successfully covered it with the clone stamp tool, but the render is taking a seemingly long time for the length of the video. The source footage is an MTS file and I've broken up the clip so it's not all one long file. Even trying to playback in AE the footage won't play even with the resolution turned down. I imported the footage over Adobe Dynamic Link from premiere but even tried doing a direct import but that hasn't changed the render time much. The final video is only 22 seconds long but is taking around 4 hours to export. I'm trying to determine if its a setting/codec issue or if it just slows my machine that much. I understand it's an intensive process but I thought my machine would be powerful enough to handle it. I'm working with the Adobe CC 2018.
Here are my computer specs:
iMac (27-inch, Late 2013)
3.5 GHz Intel Core i7
32 GB 1600 MHz DDR3
NVIDIA GeForce GTX 780M 4GB
Thanks for the help!
