Solid has 2 different colors in comp but the same #color code - looks like a ramp
Anilio Sweet
on Nov 3, 2017 at 10:51:24 am
Hello Everybody,
I have a solid with just one color in it. And i copied it so i have 2 solids and a use them to look like widescreen.
The comp size is 1280 x 720
For some reasen the solid looks like a ramp, it is brighter on te top tan the bottom.
I dont know why tis suddenly is? It is wit differnt colors also.
I have opend a new AE (CS6) project and there is the same problem, also in AE CC 2015
It is not my monitor, because the client also sees it when i sent te render.
If i tint the solid and change color it still stays the same.
And the bright side is alway above in the comp.
Does anybody knows why this is, and how i can fix it?
See attachment.
Thanks in advance
Anilio
Cassius Marques
Re: Solid has 2 different colors in comp but the same #color code - looks like a ramp
on Nov 3, 2017 at 11:55:20 am
In the first attachment, I see a single orange color.
Cassius Marques
http://www.zapfilmes.com
Mark Whitney
on Nov 3, 2017 at 2:17:00 pm
What's your text layer set to for transfer mode?
Anilio Sweet
on Nov 3, 2017 at 2:23:57 pm
thanks for reaction.
there is no transfer mode on the text, and i dont tink that is the issue.
Beacause, lik mentioned before, i opend a totally new project with only 1 solid in the comp, noting more.
That is the picure off the full orange
Dave LaRonde
on Nov 3, 2017 at 3:26:59 pm
Whar does the Info pane say when you hover the cursor over the top & botton solids?
Dave LaRonde
Promotion Producer
Anilio Sweet
on Nov 4, 2017 at 12:30:35 pm
Thanks for all the replye's
The info pan just shows the same color info numbers top and bottom!
Concerning the shading and optical illussion, if i chang it to whith without gradient it is still the same.
And if i change the BG color to black it is still the samen, and this is also with any other bg colors.
If i chang the color for the top and bottom layrs into antoher color beside organge, you stil see the
same different that the top is darker than the botom.
if i use the rectangle tool to mak e a new top and botom i still have the same color issue to.
Walter Soyka
on Nov 3, 2017 at 3:38:00 pm
The apparent change in the orange solid is an optical illusion, caused by the gradient/shading in the white background.
Walter Soyka
