import vectors from ipad to After Effects
Bruno van Wayenburg
on Nov 3, 2017 at 9:54:30 am
Hi people, Is there any ipad app which allows me to draw vector images, and then import them as masks/paths/shape layers into After Effects for me to animate. I love working with the ipencil, but all the vector apps I can find export pdf or svg, not ai which can be imported to AE.
I know I could use Adobe Illustrator as a go-between, but that would be adding to the workflow and also to the cost, plus I wouldn't want to draw on my desktop machine. I tried Adobe Illustrator Draw, but funnily enough, this only exports pdf or svg. Inkpad or Autodesk Graphic don't seem to do this either.
Any help would be appreciated.
Cassius Marques
Re: import vectors from ipad to After Effects
on Nov 3, 2017 at 11:59:54 am
You can still create shapes from a vector pdf. I'm just not sure how much compatibility you'll get from any third party generated pdf.
But have you tried the create shapes from path's command?
Cassius Marques
http://www.zapfilmes.com
