Working with mouse and keyboard in After Effects gives weird problem.
Finn Nielsen
on Nov 2, 2017 at 2:24:50 pm
I have a really weird problem.
When I work in Adobe After Effects and drag an image into My placeholder, I can drag the image with the mouse, but if I use the keyboard, I can no longer use the mouse. If I then press the screen outside After Effects and press a key on the keyboard, I can go back to After Effects and use the mouse, until I use the keyboard again.
Is there someone who knows about this problem and knows how to solve it?
Richard Mazikowski
Re: Working with mouse and keyboard in After Effects gives weird problem.
on Nov 3, 2017 at 2:19:54 pm
What hardware are you using? Is your mouse and keyboard plugged directly into your computer or do the go through another device like a USB hub? If they do try plugging in directly and rebooting.
Richard Mazikowski
rmazikowski@comcast.net
http://vimeo.com/maz1
Finn Nielsen
on Nov 4, 2017 at 10:15:48 am
I have now solved my problem. It turned out to be windows that was the problem. After an update of windows, everything seems to be working.
I thank you for your help!
