Do face tracker points have an index associated with them?
Dominic Burgess
on Oct 30, 2017 at 5:11:48 pm
Hi, I'm trying to write (what I think is probably) a simple expression to link multiple puppet tool pins to face tracker data. I want to be able to paste a universal expression into all the puppet pins which will then link them to a particular layer's face tracking data. The expression also needs to reference the puppet pin number so that it knows which face tracking point it needs to be driven by.
So, in a very easy to understand way, this is kinda what I want to do in the expression:
- Reference the number of the Puppet Pin that the expression is applied to.
- Reference the layer that the face tracking data is on.
- Use the Puppet Pin number to identify which tracking point it needs to link to on said layer. eg Layer 1, Puppet Pin 01 LINKS TO Layer 2, Face Tracking Points, Chin.
Does that make sense?!
Any help would be much appreciated!
Dom
PS. This is part of me trying to work out a bigger problem, see here...
https://forums.creativecow.net/thread/2/1125058
