Convert Wiggle Paths to Keyframes?
Emmanouil Stavrakakis
on Oct 26, 2017 at 8:32:19 pm
Convert Wiggle Paths to Keyframes? Is it possible? I need to have the wiggled line keyframed. I know I can convert an expression to keyframes easily but is it possible to get the keyframes of the layer effect - wiggle paths?
Thank you
I found this on the adobe forums unanswered unfortunately, just pasting it here, it may express my question better.
I was wondering if there is a way to access modified path information of a shape layer after operations like wiggle path or zig zag are calculated.
Pretty much like a "Convert Expression to keyframes" which reads the calculated values of a property and output the result of that on keyframes, I'd like to be able to take a path, apply operations on it and output the result of that as a new raw path keyframe.
I came up with this question when i noticed that the Bodymovin extension failed to export animations that used path operations (the extension ignored them entirely).
I see that feature as being useful in other cases as well.
If anybody have any idea how to work around this, let me know.
