CTI moving in time weirdly
Sebastian Moreno
on Oct 24, 2017 at 11:42:12 am
Hi all
I am doing a quick script to move the current time indicator to a new time given by a edittext field.
so far works to go backwards but behaves differently when I try to go forward in time:
btn01.onClick = function () {
var textInput = Input.text;
var active = app.project.activeItem;
active.time -= textInput; //works fine
btn02.onClick = function () {
active.time += textInput;
// works in a digit + digit way
// so if I entered 1 and the current time is 1 it would be: 1+1=11
any ideas how this can be solved?
Thanks in advance
Walter Soyka
Re: CTI moving in time weirdly
on Oct 24, 2017 at 1:34:30 pm
activeTime is being recast as a string because textInput is a string. Therefore, the number 1 is being recast as a string '1' and then concatenated with another string '1', yielding '11'. You want to make sure that your textInput is understood explicitly as a number.
Try:
activeTime += parseFloat(textInput);
Walter Soyka
