Vector crispness when compressing
Katie Cadwallader
on Oct 20, 2017 at 2:07:49 pm
Hello all,
I've rendered a vector animation, file size is 1.2GB (it's quite long) I've uploaded a screenshot.
When uploading to Vimeo, it's compressing it which creates a halo type shadow around each vector. Same when I compress through Quicktime.
Is there a different way to render this out so it's small enough to upload while keeping the sharpnesss?
Many thanks,
Katie
Daniel Waldron
Re: Vector crispness when compressing
on Oct 20, 2017 at 2:19:32 pm
What are your current export settings? I've exported to Pro Res before uploading to YouTube in the past, but I'm not sure Vimeo allows that. I probably makes a minimal difference anyway. Adobe Media Encoder has H.264 presets for Vimeo that I typically use now. Bumping up the bitrate may help, but unfortunately Vimeo is going to re-compress whatever you upload anyway so it may not solve the issue.
