Pre-Rendering format?
Michael Dominic
on Oct 20, 2017 at 12:54:05 pm
My computer just can't get through the export in Premiere a film that I have remastered.
I need to pre-render each scene that is dynamically linked in AE.
By default the video format for pre rendering is set to Animation. My end project will be ProRes. Should I pretender in ProRes?
I don't want to lose any quality and I wan't to avoid artifacting at all costs.
The original video is captured from DV and uprezzed to 1080, then color corrected in AE.
Thanks.
Michael Dominic
Re: Pre-Rendering format?
on Oct 20, 2017 at 2:52:53 pm
OR, is is better to render and replace in Premiere?
I generally never have the need to pre render because the graphic work I do is generally worked on until the final export (and then often times after).
Walter Soyka
on Oct 20, 2017 at 3:48:23 pm
[Michael Dominic] "OR, is is better to render and replace in Premiere?"
Yes, render and replace in Premiere.
Walter Soyka
Michael Dominic
on Oct 20, 2017 at 4:09:13 pm
Thanks, Why is this better?
