Infinite White BG Question...
Gerry Cast
on Oct 19, 2017 at 2:37:13 pm
Hi. I'm shooting a narrator against a 9 ft. wide, pure white background, and if I don't turn the XF100 sideways, I can't get the full body shot, head to toe. But when I do turn the camera sideways to fix that, in post I don't have enough white on each side as I can see the light stands. To add white to the sides, my idea was to insert a video track using a color matte, use the eyedropper to try to sample the white, draw a mask around the subject and then feather the mask. It "sort of" looks ok, but the white doesn't exactly match if you look very closely. I'm wondering if I'm doing this correctly or if there's a better way. Thanks.
Johnny H
Re: Infinite White BG Question...
on Oct 19, 2017 at 2:54:21 pm
I would shoot a "plate" and use that to fill the other sides. Flip them on both sides so the same edge is matching the middle shot with the person. To make a "plate" basically shoot the same scene without the person and nothing else. Just the white background.
John Hudson
Bright Light Visual Communications
Gerry Cast
on Oct 20, 2017 at 4:01:39 pm
Thanks Johnny. I'll try that. Great!
