Pre render mov replaces Composition
fabienne de vries
on Oct 19, 2017 at 9:33:01 am
whenever I pre-render a composition, After Effects automatically replaces the composition with that mov. Why is it doing that and how can I turn it off because I don't like it :)
Walter Soyka
Re: Pre render mov replaces Composition
on Oct 19, 2017 at 1:54:42 pm
[fabienne de vries] "whenever I pre-render a composition, After Effects automatically replaces the composition with that mov. Why is it doing that and how can I turn it off because I don't like it :)"
That's exactly what pre-rendering [link] does -- it renders a composition and replaces its usage with the rendered output.
What are you trying to do? Perhaps you'd rather use a proxy [link] workflow? Although most folks think of proxies as low-resolution or low-quality versions of a comp, there's nothing to stop you from using high-quality renders as proxies to speed up your work.
Walter Soyka
Dave LaRonde
on Oct 19, 2017 at 3:27:22 pm
[fabienne de vries] " Why is it doing that and how can I turn it off because I don't like it :)"
There is a check box -- or perhaps two -- when you use the Prerender aoption. You can select whether to simply Import the prerender, or Import and Replace. I think you have the second choice selected.
Dave LaRonde
Promotion Producer
