Wave Warp + vectorial composition
Laura Maugeri
on Oct 18, 2017 at 9:57:40 am
I have a problem with the effect "Wave warp".
When I active the button to keep vectors (I don't find the name of this button in English), my effect is changed.
On this image, you can see the effect that appears correctly :
When I active the button (encircled in red on the image), the waves changed :
The compositions and the layers inside is all in 3D.
Do you have any ideas to combine the Wave Warp effect and keep the vectorial quality in the same time ? Thank you in advance.
Richard Garabedain
Re: Wave Warp + vectorial composition
on Oct 18, 2017 at 6:42:41 pm
Wave warp has a setting pin all edges....That should do it
Laura Maugeri
on Oct 18, 2017 at 7:17:51 pm
Yes, it works ! Thank you very much !
