shape layer intersect rectangle with open path line
Kiss Istvan Robert
on Oct 17, 2017 at 6:10:52 pm
I have a shape layer that contains a rectangle and an opened path. When I merge them and apply a stroke I get a weird line between the first and last point.
why? If I put the stroke inside the path and then merge, it shows nothing.
I can use a mask and it works fine, but I want to know if there is a way to make it work only with shapes.
