Displacement Map doesnt work well
Yossi Saiada
on Oct 14, 2017 at 9:45:36 pm
I'm trying to make a glitch effect by using the Displacement Map effect
but I'm getting something else.
Screenshot:
https://image.prntscr.com/image/q5r9bOdURv2slCh0eU9m5A.png
Brendon Murphy
Re: Displacement Map doesnt work well
on Oct 16, 2017 at 6:15:47 pm
Based on the description of what you want, you will need to create a separate texture for the displacement. For instance, you could:
-create a new solid with a fractal noise effect on it
-Set the noise type to "Block" and increase the contrast
-Precompose the solid (Move all attributes")
-Choose the precomp as your displacement map layer
-Where it says "Red" and "Green", set both of those to "Luminance".
If you animate the evolution of your fractal noise, you should now see it affecting the text.
Brendon Murphy
________________
Visual Effects
http://www.brendonmurphy.net
Brendon Murphy
on Oct 16, 2017 at 6:16:48 pm
And actually, the featured tutorial on the homepage today covers this exact effect:
https://library.creativecow.net/gleissenberger_tobias/adobe_after_effects_g...
Brendon Murphy
________________
Visual Effects
