Cinema 4D renderer
Martin Stacey
Cinema 4D renderer
on Oct 11, 2017 at 12:38:16 pm
Hi, I'm planing on using the Cinema 4D renderer and wondered if anyone had any advice about it regarding speed. My thinking is that it seems to just launch c4d and render in that, so there should be no speed difference between AE and C4D, but i've also read some things about it being much slower.
Walter Soyka
Re: Cinema 4D renderer
on Oct 12, 2017 at 1:07:57 pm
I haven't found the C4D renderer to be that slow. For me, the question is more about the toolset: do I want to use Ae's design tools for a particular job, or do I want to use C4D's design tools?
Two thoughts on speed:
1) The C4D renderer may be slower than most Ae artists are used to. Real 3D gets pretty heavy, when compared with 2D or 2.5D.
2) Working with the C4D renderer in Ae may feel less responsive than working in C4D, because C4D has a separate viewport renderer and the production renderer. You can use Ae's Fast Draft preview mode for layout and toggle back and forth to the real renderer to check the look.
Walter Soyka
