CC Vector Blur Path
Lorenzo Farò
CC Vector Blur Path
on Oct 4, 2017 at 12:46:05 pm
Hi there! What I need to do is set the vector blur map that recreates this effect https://imgur.com/a/7wVPo
or these :
https://imgur.com/a/pXeUT
https://imgur.com/a/3iZhL
https://imgur.com/a/sgV5E
https://imgur.com/a/5GtNi
https://imgur.com/a/eZIQd
What I managed to do is something like this :
https://imgur.com/a/YzCpL
https://imgur.com/a/dxL7f
Do you know a way that recreates a blur path like the first pictures?
Thanks in advance :)
Michael Szalapski
Re: CC Vector Blur Path
on Oct 4, 2017 at 2:00:13 pm
Does it have to use CC Vector Blur? The examples you're showing all look like Radial Blur (or similar).
- The Great Szalam
Lorenzo Farò
on Oct 4, 2017 at 2:12:47 pm
Obviously I'm not fixed on the option it's vector blur, but's the one that is more similar.
Also, I tried a radial blur but if you observe the pics the blur has at least two different directions and angles.
If you have any other idea I'll be glad to accept it :)
Kevin Camp
on Oct 4, 2017 at 6:51:38 pm
i'm not sure what you are using for your vector blur map, but i think if you use a simple radial gradient on a solid (or shape layer) as the vector map you should start to get a 'zoom blur' effect. tweaking angle and other settings may get the effect you are looking for.
Kevin Camp
Art Director
KCPQ, KZJO & KRCW
Pierre Jasmin
on Nov 10, 2017 at 6:50:58 pm
FYI (sorry for the advertising)- you can always try SmoothKit Directional With Splines (in SmoothKit plugin by us, RE:Vision Effects), it allows you to shape directly a blur using AE masks. It takes a bit to understand how to control falloff with soft mattes...
Pierre
