Can't select shape layer to set first vortex
Sharyn Murray
on Sep 28, 2017 at 11:52:32 pm
Performing my first shape morph to a shape layer. Can't seem to select a point to set first vortex. Have attempted this 1. by selecting the shape layer itself,
2. by selecting the group and
3. by selecting the keyframe of the path and right clicking.
Any help appreciated.
Angie Taylor
Re: Can't select shape layer to set first vortex
on Sep 29, 2017 at 6:50:17 am
You need to select an individual point on a path in order to be able to set the first vertex.
To do this choose the selection tool and then click on the point on the path that you wish to be the first vertex. Now the menu option should be available for you to set the first vertex.
cheers,
Angie
Angie Taylor animation & illustration for television, film, web and devices
http://www.angietaylor.co.uk
Twitter: theangietaylor
Linkedin: theangietaylor
http://www.facebook.com/pages/Angie-Taylor/118378194869002
Sharyn Murray
on Oct 2, 2017 at 11:03:05 pm
Angie, thank you for your answer. The problem is that I can't seem to select a point. I've been using Adobe products for over 15 years so I definitely know how to select or direct select a point. Once I can select a point, I definitely see the other steps. It's not a hard process, just stumped on selecting a path point.
Chris Graves
on May 10, 2019 at 2:45:17 am
You might be using one of the predefined shapes (ie, rectangle, ellipse, polystar). I don't think you can direct select a single point on those. You'll need to convert it to a path first.
If you twirl open your Contents and your "Rectangle Path" and see a size and position parameter, then you're using a predefined shape. Right click on the words "Rectangle Path" in the timeline and you'll have the option to "convert to Bezier path".
Be warned that once it's a path you'll lose the size and position parameters, so if you need those then don't convert. Instead add a Trim Paths and tweak the offset parameter until it starts at the point you want.
