Import DPX as a sequence in After Effects
Lauren Quinn
on Sep 28, 2017 at 1:12:10 pm
Hi all
I am trying to import a folder of DPX into after effects, and then arrange the DPX in the composition as a sequence. I have successfully imported the DPX however when I select all, right click and choose New comp from selection, they are all added to the composition as stacked layers at the playhead, rather than a series of images. Is it possible to get them to be added to the composition as a sequence rather than a layer stack?
Mark Whitney
Re: Import DPX as a sequence in After Effects
on Sep 28, 2017 at 2:21:37 pm
Try importing the folder with the files instead, although it's quite odd that the normal method is doing that.
Walter Soyka
on Sep 28, 2017 at 3:26:08 pm
Don't import the folder; import the first image and make sure that "Import as sequence" is checked in the Import file dialog box. If you're on a Mac and you don't see the "Import as sequence" option in the dialog, click the "Options" button on the lower left corner.
Walter Soyka
Mark Whitney
on Sep 29, 2017 at 2:20:11 am
That's the normal method certainly.
FWIW though, I just finished a project, using DPX sequence, imported the folder, right clicked and end up with a normal single layer composition.
However, if I try that with a folder that has sub-folders, then the Requestor box may come up and even with selecting single comp and 1 frame per image, I get the same results your experiencing. Haven't tried this with other file formats though.
