Need assistance locating a plugin file inside of After Effects
Gina Miller
on Sep 27, 2017 at 3:37:21 pm
Can anyone help? I am getting this After Effects error: "Couldn't find main entry point for Picasso.plugin”. This error causes AE to crash at startup. I am using a Mac.
I was having a difficult time finding info about it so I asked someone on Youtube the exact question above. This is as close to an answer as I got, he gave me a path to it’s location on a PC but I can’t seem to translate it to Mac. Please read the conversation we had below as it explains in more detail where I am at with this problem.
He said:
Sounds like an issue with the Picasso plugin - your best bet is to contact the company you got the plugin from :)
I said:
Before I try that I would like to find the actual plugin file in the AE program files so that I can try removing it to see if it works. I had another error for a different plugin and when I located it in my plugins folder and removed it, I did not have that error anymore. I can't find this one (Picasso.plugin) in my plugins. I'd like to find out where it is so I can try removing it first. Do you remember who makes it? If I just google the plugin, I don't find anything, makes me wonder if it's a part of something rather than a plugin, unless you know different.
He said:
I can see a Picasso.aex plugin file in the usual spot - C:\Program Files\Adobe\Adobe After Effects CC 2017\Support Files\Required I'm on Windows though so you'd have to translate that to whatever path that is on a Mac
I said:
I do have a Mac, I looked in Applications/AdobeAfterEffects CS6/Plug-ins and I also looked in Macintosh HD/Library/Application Support/Adobe/Common/Plugins to no avail. Don't see a required, do you know where that would be?
--That’s where it left off, I haven’t heard back. Hoping some one here can help.
Walter Soyka
Re: Need assistance locating a plugin file inside of After Effects
on Sep 27, 2017 at 6:13:41 pm
Picasso is the codename of Ae's original ray-tracing 3D renderer (introduced in CS6).
I think you should first try resetting your preferences (hold Command+Option+Shift while Ae is starting). If that doesn't work, I'd suggest you uninstall and reinstall Ae.
Walter Soyka
Gina Miller
on Sep 27, 2017 at 6:35:50 pm
Will this remove my plugins?
Walter Soyka
on Sep 27, 2017 at 6:51:19 pm
It should not remove anything in the MediaCore plugin folder, but it might remove plugins in the main Ae application folder. You should back up first for sure!
Walter Soyka
Gina Miller
on Sep 27, 2017 at 7:07:16 pm
Walter I am looking at this video
Is the Render Button drop down in the top right something that I could change? I can get into AE I just can't open/or create a project or it will crash. I was wondering if this is something I can change or fix in AE, however I do not see that render drop down.
