best way to achieve 'erratic pulsing' of a path (with example)
Chee Seng
on Sep 25, 2017 at 1:34:52 pm
Hi everyone, I'm currently animating a logo for a graphic designer and i'm looking for a neat solution to create an effect in the same vein as this pulse;
The client requires the animation in html5 as well as .gif format, so I think i'm looking for a 'shape layer/expression' based solution.
I've designed an animation which trims these paths on in an interesting way and the client wants a pulse or glow at the end. It may be my limited understanding of HTML5 animations, but most effects (even most layer styles) are not rendered when I use 'bodymovin' to export the .json file, hence why the animation below is created using only paths being trimmed on.
Any advice on 'effects' or techniques I can play with to create this effect would be appreciated.
