Render Quality
Ramnan Arumugam
Render Quality
on Sep 23, 2017 at 9:55:48 am
I was working on a simple vector(which I created in AE itself) animation which involves text. I converted it to a png sequence to make a gif using photoshop. The final output alwways appears to be smoothened and a bit blurred. All vector layers are a bit blurred especially the text. How to get a sharper output?
Remus Hosu
Re: Render Quality
on Sep 23, 2017 at 9:56:15 pm
Hi Ramnan,
You cannot create vectors in AE, but you can import vector files. If that is the case, did you turn on the continuously rasterize option for that layers? Also, you can export gifs directly from media encoder, there's a preset for that. Here's how to do it:
https://bluefx.net/make-animated-gifs-effects-post-facebook/
