What is the depth/volume effect used in this Kenzo commercial?
Benjamin Penaguin
on Sep 22, 2017 at 9:22:19 am
Hi everyone,
I was wondering what would be the closest way to achieve this effect, in the sequence starting at 0:18 in the video.
It seems like some sort of depth map that uses colors as a scale of value.
In your opinion, was it made in After Effects, Cinema 4D, etc...? Could it be a specific plugin?
Thank you,
B
Cassius Marques
Re: What is the depth/volume effect used in this Kenzo commercial?
on Sep 22, 2017 at 8:35:03 pm
If one would do that in C4d it becomes somewhat simple. Get a fractal image such as those. Add a high res plane, a displacer deformer that maps luminance to height. Use the same image as a difuse texture and you're pretty much half way there. The rest are camera moves and some extra displacements/subdivides.
Cassius Marques
http://www.zapfilmes.com
Benjamin Penaguin
on Sep 23, 2017 at 12:32:28 pm
Hi Cassius, thank you, I'm definitely going to try that.
Best,
B
