Problem with rotating 3D shapes
Freek Van Der Beek
on Sep 20, 2017 at 8:32:15 pm
Hello everybody,
I can’t find the solution to properly Y-rotate a shape i created in 3D around it’s center.
If i make a circle and want to rotate it on the Y axis, it shifts the center on the left and right out of proportion, as if the center is shifted constantly.
The effect i try to create is basically have an ellipse stretching in and out.
Everything is symmetrical; the shape, the composition, camera values.
Here’s what AE does now:
And this is the effect that i woud like to achieve (manually adjusted, sloppy):
I really hope someone can help me with this.
Thank you
Jim Scott
Re: Problem with rotating 3D shapes
on Sep 20, 2017 at 9:44:53 pm
With the layer selected, go to Layer > Transform > Center Anchor Point in Layer Content.
