Stroke dash rotation thing messup
Radin Hakimjavadi
on Sep 17, 2017 at 6:19:05 pm
I dont know what to call this, but when I make something like this:
https://gyazo.com/7f685e31af8f6e02675a078ad4018226
and start to make it 'rotate':
https://gyazo.com/5d5cab015b3b7d769c155e5fb5e8798f
the top right doesnt wrap correctly. I really want to fix this because its extremely annoying.
Greg Gesch
Re: Stroke dash rotation thing messup
on Sep 17, 2017 at 11:49:41 pm
Hi Radin. I presume you are using a shape layer to create this? I also imagine that the upper right corner is the first vertex? If so, the strokes appear at the first vertex and disappear when they reach the first vertex as well - they don't wrap around. So it's a balancing game between the length of the stroke and the distance it needs to travel so that it appears to be wrapping around the corner. I'm sure some mathematical wiz here could give you a formula but in this situation I've always just played with the length of the stroke or the size of the path until it looks right.
