Adobe after effects Lights
Jineesh kottiyoor
on Sep 17, 2017 at 8:50:29 am
Hi all,
I am working with aftereffcts cc and Element 3d, Creating some lighting setups with after effects and while adding rthe lights its working awesome, But the problem is that once add 8 lights (any lights) into the comp=, 9th light is turning off the first light. That means i can use only 8 lights in a comp. Do anyone faced same issues and do have any solutions for this?
Jim Scott
Re: Adobe after effects Lights
on Sep 17, 2017 at 3:00:26 pm
I cannot reproduce your issue in either AE CC2017 or CS6 on a Mac. I have added 50 spot lights to a scene (both with and without an Element 3D layer) and they all remain illuminated.
Good luck.
Jineesh kottiyoor
on Sep 18, 2017 at 3:58:06 am
Dear Jim Scott,
Thats something really new for me. Is it possible to share a scene where you used more than 8 lights.
Thanx
Jim Scott
on Sep 18, 2017 at 5:17:19 am
[Jineesh kottiyoor] "Thats something really new for me. Is it possible to share a scene where you used more than 8 lights."
I have never created a project where I used that many lights on purpose. I was simply testing to see if I could reproduce your issue, and even after adding 50 lights they were all working fine.
Jineesh kottiyoor
on Sep 18, 2017 at 5:56:38 am
Hi Jim Scott,
I tested out with default 3D layer within after effects and the 9th light is working fine with after effects rendering. But the problem is with element 3D layer. Only 8 lights are working with element 3D.
