Hair overshoot for a character
Zoltán Riskó
on Sep 13, 2017 at 7:32:02 pm
Hey guys,
I would like to add an overshoot effects for my character's hair by expression. I found Dan's awesome keyframe overshoot script which is awesome but i would like to modify it a little bit.
Here is my result now, but not perfect:
https://1drv.ms/f/s!AlEKHWwr-X-pgc9wK17TctDux98GAw
Now the hair has 3 puppet pins which are linked to 3 null objects. The null objects have a hierarchy by code so i need to move the parent only.
But i can only achive the overshoot if ad keyframes to the second and the third null objects too but i want to avoid it.
Is there any trick to add a parent or something like that to the code so i don't need to add keyframes to the second and third null object but achive an overshoot effect?
For example: ( sorry I'm not too good with expressions :P )
freq =thisComp.layer("Settings").effect("Freq")("Slider");
decay = thisComp.layer("Settings").effect("Decay")("Slider");
myparent=thisComp.layer("1").transform.position;
n = 0;
if (myparent.numKeys > 0){
n = myparent.nearestKey(time).index;
if (key(n).time > time) n--;
if (n > 0){
t = time - key(n).time;
amp = velocityAtTime(key(n).time - 0.01);
w = freq*Math.PI*2;
thisComp.layer("1").transform.position + value + 15*(amp*(Math.sin(t*w)/Math.exp(decay*t)/w));
}else
thisComp.layer("1").transform.position+value
Thanks guys (and sorry for my english )
