Audio react plugin or script?
Yanda Satria
on Sep 5, 2017 at 9:24:22 pm
So, i know how to do audio react, by using audio waveform or spectrum, or do it manually using keyframe assistant and so on...
mostly i use the keyframe assistant technique, but, now i'm working with a band which constantly produce song with audio react motion graphic background...and...
i am wondering if there are any plugin or script that does audio react, like trapcode form's audio react...which will save me some time...
form's audio react is already good enough but it requires me to put 1920x1080 particle which is so heavy to render.. ☹
i've search the internet but no luck so far, the closest one is something called 3d audio react but it's in korean... ☹
thanks
Walter Soyka
Re: Audio react plugin or script?
on Sep 6, 2017 at 5:20:18 pm
You could use Trapcode Sound Keys to extract much more detailed information from audio than you get from Audio to Keyframes. You can use that output to make any effect you like audio reactive:
http://www.redgiant.com/products/trapcode-sound-keys/
Walter Soyka
Yanda Satria
on Sep 6, 2017 at 5:46:41 pm
exactly what i'm looking for, thanks... :D
"We will either find a way, or make one".
-Hannibal Barca-
