what kinda of mask is this?
5ense Xee
on Aug 23, 2017 at 8:24:26 pm
at 0:15:0:16 there is a circle around the charachter and inside white fill, what kind of mask is this?
Steve Bentley
Re: what kinda of mask is this?
on Aug 23, 2017 at 11:27:01 pm
I'm not sure what you are seeing but you can just apply the fill effect to fill a mask with color. You can feather the edges of the mask, invert it, mask it with other masks, all within the mask controls.
Stefan Christopher
on Aug 24, 2017 at 3:24:31 pm
You can achieve that sort of effect by selecting your layer (in this case the Army guy on a transparent background) and then going to Layer/Auto Trace in After Effects. You'll then get a new solid with the mask of the Army guy on it which you could then add a stroke or a fill to to generate the same type of effect as in the video.
