Contentiously Rasterize problem
anas sabih
on Aug 22, 2017 at 11:52:30 am
Hey all, I wanna ask something.
When i enable rasterize on a layer that I already made an effect on it like puppets and such, the layer returns to its original phase.
Like I have a hand that is moving through the poppet pin, but when I enable rasterising on it, the puppets change its place and are extended outside the comp, and the hand stands still.
Why is that happening, what am I doing wrong ?
Thank you
Eric Santiago
Re: Contentiously Rasterize problem
on Aug 22, 2017 at 1:27:48 pm
You will need to do a chicken or egg test.
Basically, you have the order mixed up as far as comp (assuming you have pre-comps).
anas sabih
on Aug 22, 2017 at 1:50:39 pm
what do you mean ?
sorry I did not understand .
Stefan Zerdzinski
on Aug 24, 2017 at 3:29:59 pm
Why are you enabling continuous (not contentious, although arguably it has lead to many fallings out in the past) rasterisation on the layer in the first place? If we know the reason it will be easier to find a solution / workaround.
Roei Tzoref
on Aug 26, 2017 at 7:37:57 am
Anas, when using puppet you should not use CR switch. The explanation is in the help files under puppet.
Roei Tzoref
2D/VFX Generalist & Instructor Ae Blues Tutorials
http://www.tzoref.com
