Element 3D Layer Timing Glitch
Kenan Bateman
on Aug 19, 2017 at 11:48:56 pm
I'm struggling with an Element 3D source layer and I can't figure out why the timing is glitching.
I have a credit card I've created and the back of the card is referencing a composition as it's diffuse map.
Everything is set to Current Time and there are no cuts or time remapping or anything applied anywhere. Yet it picks a random frame from the comp and uses that as the source (even though Random Time isn't selected....current time is). What's weirder is the frame changes randomly too.
I'm referencing 0:07 - 0:09 in the CC comp. This is also nested in 0:22 - 0:24 in the Final comp.
If you can figure out what's going on here, I would be extremely thankful.
11610_nyftypaycard.aep.zip
