Remove light box
Major Attila
Remove light box
on Aug 19, 2017 at 7:07:23 pm
Hello there. I am using this plug-in named Saber for after effects, and I have some issues. I'd like to know if there is a way to hide that light, it looks like there is a box and the light stops there. I attached an image so you can see what I am talking about.
Leopoldo Perizzolo
Re: Remove light box
on Aug 26, 2017 at 3:08:27 pm
The box effect is probably caused by the layer on which you applied the effect being too short in height; try applying the effect on a bigger solid layer, so that the boundaries are out of the comp and not visible.
Leopy
