Maintaining stroke widths within a 3d enabled precomp regardless of camera position.
Sam Burrough
on Aug 17, 2017 at 4:36:09 pm
I am working on a 2d animation project which requires that all the line art stoke widths remain at 1px at all times.
I can use Dan Ebberts' amazing expression to maintain stroke widths for shape layers, but I have no idea how I would go about maintaining the stroke widths of shape layers that are within a precomp layer when tracking in close with the camera.
Just wondering if anyone has tried to achieve this before and if so how did you get on?
“To country people Cows are mild,
And flee from any stick they throw;
But I’m a timid town bred child,
And all the cattle seem to know.”
Dave LaRonde
Re: Maintaining stroke widths within a 3d enabled precomp regardless of camera position.
on Aug 17, 2017 at 5:55:42 pm
[Sam Burrough] "I am working on a 2d animation project which requires that all the line art stoke widths remain at 1px at all times."
That's a no-win requirement. A very bad requirement.
No matter what precautions you take, that stroke is going to shimmer, oftentimes appear pixelated and occasionally parts will disappear if you animate its position. If this animation will at some point have smaller vertical & horizontal dimensions it stands an excellent chance of disappearing entirely.
I expect the individual who established this requirement has little or no experience in animating bitmapped graphics. You need to explain the limitations & realities ov video to this individual.
Dave LaRonde
Promotion Producer
Sam Burrough
on Aug 18, 2017 at 9:09:57 am
Hi David, thanks for getting back to me. I have explained some of the difficulties you mentioned above. I have now been provided with a reference which might help illustrate the desired result a little better. The following screenshots and gif are take from Buck's Amp awards opening titles. As you can see the stroke width of the line art remains the same even when elements move towards or away from camera:
Dave LaRonde
on Aug 21, 2017 at 5:56:51 pm
Having looked at that animated gif maybe a dozen times or more, I have to ask myself why it's so important to maintain constant pixel size. There's so much going on that it's largely irrelevant, in my mind.
Further more, you specified ONE PIXEL WIDE. That's the kiss of death for just about any video animation. For one thing. it's virtually invisible in the first place. For another thing, when the animation gets compressed -- and it will -- that one-pixel line will disappear on a haphazard basis.
You just don't make 1-pixel lines in video animations. It's extremely bad practice.
Dave LaRonde
Promotion Producer
Kevin Camp
on Aug 17, 2017 at 6:07:04 pm
you might be able to link the distance between the pre-comp and the camera (in the main comp) to the stroke values in the pre-comp.
if you post the expression, we could take a look...
Kevin Camp
Art Director
KCPQ, KZJO & KRCW
Sam Burrough
on Aug 18, 2017 at 8:31:25 am
Hi Kevin,
Thanks, here's Dan's expression:
nominalDist = 400;
d = length (thisComp.layer("Camera 1").toWorld([0,0,0]),toWorld(anchorPoint));
value*(d/nominalDist)
(Set nominalDist to the distance where you want the stroke width to be the value you have it set to)
Kevin Camp
on Aug 18, 2017 at 7:12:47 pm
[Sam Burrough] "d = length (thisComp.layer("Camera 1").toWorld([0,0,0]),toWorld(anchorPoint));"
in that line of your expression, try changing thisComp to the comp("NAME OF COMP WITH CAMERA"), where you replace [NAME OF COMP WITH CAMERA] with the name of your comp that has the camera and the pre-comp in it.
Kevin Camp
Art Director
KCPQ, KZJO & KRCW
Sam Burrough
on Aug 21, 2017 at 8:54:55 am
Will give this a go and report back, thanks Kevin!
Cassius Marques
on Aug 17, 2017 at 9:19:13 pm
Your title is a little misleading... you will never be able to mantain the width if you rotate the camera without enabling "auto orient" on the precomp. That would require a 3d path and would be outside AE's standard capabilities.
Its doable If all you need is to translate camera Z distance from a pre comp to a stroke width inside it. I'm sure Kevin can help you with that.
Cassius Marques
http://www.zapfilmes.com
Sam Burrough
on Aug 18, 2017 at 9:12:35 am
Thanks Cassius, I posted the expression above.
