CC Glass Bump Map: composition and footage give different results
Jeremy Paul
on Aug 16, 2017 at 5:50:21 pm
I've followed a neat tutorial on making a rain drop on a surface. It uses bunch of Turbulent Displacements and Particle effects to create a black and white bump map.
That map is fed into CC Glass to create refraction. I wanted to render just the black and white bump map to avoid overhead with Turbulent Displacements etc...
My problem is, that when I use a video of image sequence of a bump map, cc glass renders completely different than if I use the actual composition, created at runtime.
Check this images:
With prerender as bump map: http://imgur.com/a/WrEx9
With composition as bump map: http://imgur.com/a/gjwzj
When I use a video as bump map I got awful a lot of pixelation going on. To further prove my point, check this image of a bump map composition and bump map prerender. There is 0 visual difference. And even if there are small differences, that should cause so many artifacts.
http://imgur.com/a/Nmu4b
Can someone explain why is this happening? Thanks, Mitt
Walter Soyka
Re: CC Glass Bump Map: composition and footage give different results
on Aug 16, 2017 at 6:52:44 pm
Are you working in your project at a higher bit-depth than what you've rendered?
Walter Soyka
Jeremy Paul
on Aug 16, 2017 at 7:21:43 pm
Nope. All the same.
This are the project files:
http://www.videocopilot.net/blog/2017/01/new-tutorial-realistic-rain-drop-f...
You can go into Water composition and render the bump map to see the problem in action.
Walter Soyka
on Aug 16, 2017 at 7:46:52 pm
That project is set to 32bpc.
Set the project to 8bpc; you'll immediately see the artifacts you describe. 16bpc ("Trillions of Colors") improves it considerably, and 32bpc of course is the original.
If you're pre-rendering the bump map to an 8bpc ("Millions of Colors") video format, you're losing important information. Render to OpenEXR at 32bpc ("Floating Point") for the best results.
Walter Soyka
Jeremy Paul
on Aug 16, 2017 at 8:42:03 pm
Thanks. I've prerendered to openEXR with project set to 32 bpc. The issue remains. Although I am not really familiar with all the render settings, so feel free to render it your self (it is a fairly quick render).
Walter Soyka
on Aug 17, 2017 at 2:06:03 pm
[Jeremy Paul] "Thanks. I've prerendered to openEXR with project set to 32 bpc. The issue remains. Although I am not really familiar with all the render settings, so feel free to render it your self (it is a fairly quick render)."
Sorry. The defaults for OpenEXR are not completely lossless. You'll have to go into its options and set it 32-bit floating point. It defaults to half-float.
But if it's a quick render, why bother pre-rendering in the first place? If you're not going to save significant render time, why bother with the hassle?
Walter Soyka
Jeremy Paul
on Aug 17, 2017 at 9:55:39 pm
Because it is a clean way of storing data for later reuse and it reduce render overhead at the same time. But after all this trouble, I'm just getting more curious why it doesn't work. I clearly don't get some aspect of AE.
I've completed an openEXR render with 32 bit checked. The issue remains.
I hope I not asking to much, but could you render it the PRO (your :D) way and see if it actually a render setting issue?
